Engine mount help!!!!!!
do it from below. on a lift is the easiest. hold the engine up with a tranny jack and pop them in and out. i havent looked specifically at a w202 for a while, but thats the easy way its done on most of these cars. you are just doing the rubbers, and not the metal wings that attach to the block itself, right?
you may not be able to actually see the bolt, but it should be the same size as the bottom bolt. see if you can get your hand in and feel the bolt head, and if you can, see if you can fit a wrench in to turn it. it sucks, but sometimes you just have to work blind.
