Controller Area Network
Old Sep 26, 2013 | 11:43 AM
Nytrydr's Avatar
Default Controller Area Network
I'm having an issue with my 95 Benz,C220, engine shuts down about 5 minutes after start up, all idiot lites on, then after 30 seconds to a minute it starts up & runs fine, I connected the OBD-II reader but no codes, so I changed the fuel filter thinking it may be clogged, its been running fine, no shut downs until yesterday while leaving work, car started drove about 5 mins. then engine shuts down all idiot lites on, then waited for a minute car started up & I drove home, I did connect the OBD-II & I did get a code 0600 - serial communications link malfunction (CAN - controller area network data bus) has anyone experienced this type of fault & what is the fix? Could this be an ECU(engine control unit) problem? ********Found solution - bought a new battery on 04 Oct. 13, go figure.********
LesaA
May 26, 2008 07:21 PM
mySLK230
Apr 29, 2007 07:42 AM
CarPhen
Mar 25, 2007 10:09 PM
uniquesl320
Nov 21, 2006 03:34 PM
swells
May 11, 2005 11:26 PM
