check engine light disabled?
Old Aug 5, 2006 | 05:48 PM
myk_g4orce's Avatar
Default check engine light disabled?
Hello;
How can I check if my Check Engine Light has been disabled? Is there a fuse for it?
Thx
Car;
C230 Komp 2000 140km
Old Aug 5, 2006 | 08:41 PM
RockSolid's Avatar
Default RE: check engine light disabled?
W/o thinking too long and hard-there is certainly a fuse for the lamp, but if the other lamps in the dash cluster are working then the fuse is good. Other than opening the cluster and checking the bulb, I don't know. Get a read out to see if you have any current trouble codes. If you do, then you CEL is certainly not working.
BTW, you can get a free read out from Auto-Zone or some other shop.
Hope this helps.
Old Aug 5, 2006 | 11:13 PM
rexde1's Avatar
It should light up with the key in the acc. position. If not its either burnt out or disabled.
Old Aug 6, 2006 | 03:46 AM
myk_g4orce's Avatar
aahhh! Thx guys....
appreciate it very much.
fifthsymphony
Jun 20, 2013 12:04 PM
Mr.47
Feb 12, 2008 01:44 PM
richardhb
Jun 22, 2004 02:12 AM
