CE230 Circular Plug
Old Sep 26, 2004 | 09:32 AM
joshua.W's Avatar
Default CE230 Circular Plug
Hi there , i am looking for a chart or a template for the big circular plug behind the instrument cluster , i was trying to remove the cluster not knowing such valueble forums exist , while i was trying to remove the cluster circular plug came of from where the wires are not the whole plug so they are all mix and match at the moment , went to the scrapyard but couldnt find any mercedes to check the wire combination with in the plug, they suggested all cars are same and gave me a similar 1 that belongs to another make , when i use that as a guide some lights work , some dont. Does anyone where can i find the right combination. Tried mercedes dealer they said they dont have any chart and engineer has to look at it and its £100 per hour.... i reallly need your help as its really annoying driving it like that petrol ins doesnt work , when i use selector battery lights up etc etc ......
Added 2 pictures showing the cluster and the circular plug , pictures are from another forum showing how to remove the cluster... thanks in advance...
[IMG]local://upfiles/3333/073A77ED02B84E39964E0FBA7778B302.jpg[/IMG]
[IMG]local://upfiles/3333/1C7CF07812B54AA09D1F7F2368BED52C.jpg[/IMG]
Old Sep 26, 2004 | 10:37 AM
sleepwalker's Avatar
Default RE: CE300 Circular Plug
you mean.... the wires was separated from the socket connector, and you need a guide to put them back on the right place?
something like, black wire goes to #1, blue #2, red #3..etc?
what is your VIN or chassis number?
Old Sep 26, 2004 | 10:43 AM
joshua.W's Avatar
Default RE: CE230 Circular Plug
Yes thats the problem,
VIN - WDB1240432B576380 230ce Coupe model
Thank you very much.... Cant appreciate your help
Old Sep 26, 2004 | 10:52 AM
i will send you the information tomorrow.
Old Sep 26, 2004 | 11:03 AM
joshua.W's Avatar
ok thank you very much....
Old Sep 27, 2004 | 03:15 AM
here you go joshua.
hope you're happy with it.
[IMG]local://upfiles/1/C89E4F64E56B4F84B771F6575C077B35.jpg[/IMG]
Old Sep 27, 2004 | 04:00 AM
joshua.W's Avatar
oww superb , thanks alot m8. Great help. Thanks again..
Old Sep 27, 2004 | 07:53 AM
welcome.
hope it's the right diagram. it was based on your chassis number.
Old Sep 27, 2004 | 02:45 PM
  #9
joshua.W's Avatar
yes thank you so much , at first i didnt realise some fuses were blown , so most of the stuff worked , only few didnt , after quick check on the fuses , everything is working now , thank you again ...
Demetrios87
Jun 4, 2009 05:14 AM
lizardosversoza
Apr 19, 2004 09:40 AM
pgardell
Feb 18, 2004 08:03 PM
cmscott16
Jan 8, 2004 09:16 PM
rcgiddings
Dec 18, 2003 02:18 PM
