Car shaking after ignition
Hello everybody.. Could any one help me on my C180 Elegance my2002?
Two Symptoms
1. Every time I start the car, the car is kinda shaking (very slightly) for 60 sec, and the enginee is pretty noisy... after 60 sec approximately everything turns to normal - all in a sudden, the enginee also quiet down.
2. Very occasionally (twice in 3 months), the ESP/BAS warning message would also pop up (problem gone after I restart the car). I ran through the ESP threads, it seems that I need to change the stop light switch / brake pedal switch.
Is Symptom 1 common or a type of misfiring? - But the check enginee light is not on. Could Symptom 2 caused by 1?
Thanks a lot. The help will be much appreciated.
Two Symptoms
RE: Car shaking after ignition
Hi ,
I had almost similar problem. My car was shaking continuously. Like when I am sitting inside I used to feel shakes.
Contacted stealership, they stole 600 $ and fixed it saying, some wires were fried inside.
Hope it helps
regards
Hope it helps
regards
Myran
12-06-2018 03:17 PM
brantchastain
10-02-2010 06:17 PM
