Can't find crank position sensor
I just wanted to re-title my first thread to clarify what it is I needed. I have no idea what I'm doing...so if someone can help me locate the crank position sensor so I can replace it, that would be great. I had a diagnostic ran because I have been having trouble with my car stalling out, and then refusing to turn over. If I let it sit for a while, it will crank....with no guarantee of when next time there will be a problem. I have a new sensor and would like to try and install it myself. Thanks in advance!!!!
crank position sensor location
1stmercbenz,
location is behind left cylinder head [ drivers side ] if you never did one it is hard to explain how to do. but here goes, you need # 8 inverted torx's [ female torx ] most of this you do by feel ,remove screw and replace sensor . or take to shop. charge should be about 1.0 hours
cjshade
8
11-28-2007 08:38 PM
