C280 transmission leak at shift module
Old Oct 19, 2006 | 04:30 PM
zepol0674's Avatar
Default C280 transmission leak at shift module
I have a 1998 C280 with about 75K miles. The transmission began leaking from the point at which the shift cable enters the transmission. Mercedes told me its a regular occurence and that they all start leaking from there sometime after 40K or so. Anyway, the part is $14 (plastic). No problem removing the broken half of the original part (it bolts into the transmission). No problem removing the pan and removing the old fluid. Problem? The plastic part has a small cap on the end that attaches, inside the transmission, to the notched part that actually shifts the transmission. I don't see a way to remove this spring loaded arm. It appears to be held in place by a metal bar (1/16 diameter or so) visible from the outside of the transmission casing. Can it be that Mercedes made a plastic $14 part that can't be removed without tearing much of the transmission apart? Seems illogical. Must be an easy way. Do you guys know how to get this part out? C'mon guys. Must be someone out there who has replaced this part.
bnhokie12
Jan 25, 2016 10:02 AM
sleekparts
Jan 5, 2012 08:30 PM
axm1955
Sep 13, 2007 10:07 PM
93400sel
May 8, 2006 03:55 PM
mbzcoolio
Dec 14, 2004 10:51 PM
