c270 cdi starting probs ??
[]I have been recomended by a fellow site member to check that the return pipes of the fuel system are checked to make sure I have no leaks,as I have a strting problem.Is there an easy way to check the pipes and is there a particular area I should be looking at for problem,I have changed injectors ,rail seals,low pressure pump,still have problem starting when car is left over night,I have to turn over the engine for aprox 2 mins before it fires up,it,s then ok all day but next mourning it won,,t start
any ideas[]
any ideas[]
RE: c270 cdi starting probs ??
I had the same problem few weeks ago.The plastic fuel lines are leaking and sucking air.Diesel is draining back to tank.
You need to replace the Fuel line pipe(£12) or O seal (45p)from Diesel fuel filter to injector pump.
