c230 Kerb lights for the two front Doors
Old Feb 15, 2006 | 08:16 PM
wilkinbr's Avatar
Default c230 Kerb lights for the two front Doors
Does any one know how easy it is to fit these lights to the underside of the front doors, and where one might get them from.
Here in the UK the lights are standard on the Elegance and Avantguard models but not available on the Sports Edition.
There is a small indentation in the door fabric just rear of the front door speaker housing. Is this where the light is fitted and will the wiring loom be standard so I would expect to find a couple of connectors?
Appreciate any help forthcoming.
Old Feb 15, 2006 | 10:07 PM
C280 wizard's Avatar
Default RE: c230 Kerb lights for the two front Doors
I spent some time in the UK over 30 years ago, and I never heard the term Kerb lights. What is there purpose? Are the similar to the lights on the inside of some American cars that are supposed to tell on coming traffic your door is open?
Thanks,
Old Feb 15, 2006 | 10:11 PM
Lugnut's Avatar
Of course, the proper spelling is curb lights. I've had several cars with them. They're called puddle lights here. The light up the area just outside the door so you can straddle puddles and other mucky things, and see the curb so you don't trip on it, I suppose.
Old Feb 15, 2006 | 10:21 PM
I see Kerb = curb OK, now I get it.
Old Feb 16, 2006 | 01:47 AM
sleepwalker's Avatar
your car don't have it because it's classic or sport version.
however, you can install them since it only get actuation signal from door control module. (connector #7, pin 2 & 3).
it is now called door entrance and exit lamp.
Old Feb 16, 2006 | 06:20 PM
wilkinbr's Avatar
Thanks for the info. Is the connector found behind the door speaker?
By the way Kerb in the UK is the edge of what you would call sidewalk and curb means control. I guess I should have used "curb" as I want to control some lights.
Old Feb 16, 2006 | 10:05 PM
door control module connector.
Old Apr 30, 2010 | 03:02 PM
rayjay120's Avatar
@ sleepwalker
is connector 7 populated or do i need to buy a plug for it'
thanks
Rayjay120
Aarohead
Nov 12, 2020 11:21 PM
blakey Merc
Feb 5, 2011 11:51 AM
s40guy
Jan 27, 2009 02:59 PM
ptldMerc
Sep 22, 2007 04:03 PM
cbrizzle
Sep 20, 2007 04:24 PM
