c230 coupe lost of power
Old Aug 2, 2007 | 03:35 PM
mbgt's Avatar
Default c230 coupe lost of power
hey all
recently i`ve notice a really significant lost of power, i recently replace a check valve that is locades on the back of the engine close to the ingention and that valve is conceted to another vaccum valve. there are 2 thngs.
1) every morning when i start the car I hear a blowing sound liki if air is coming from the supercharger when this happends the car works great and fine the rest of the day
2) if I dont hear that sound i know for a fact that the car is going to lose alot of power.
3) if i disconnect the battery and re conected and put the key in switch for a wile and then disconect the key and the start the car works fine for a cuple of days and the again the prolem.
any ideas
cheers
Old Aug 2, 2007 | 05:02 PM
NAZ's Avatar
NAZ
Default RE: c230 coupe lost of power
yeah its called air recultion pump that could be playin up if thats inop espealy on the komppressorengines it does effect the power have it dignosed by MB u ll nothe exact fault.................let me no hw u get on.........
Old Aug 2, 2007 | 05:08 PM
mbgt's Avatar
is that the actutaor on the top of the supercharger manifulld
Old Aug 3, 2007 | 04:26 PM
NAZ's Avatar
NAZ
first of all you ve got to have a dignostic test before anything and take it from there if its the actuator its not that expensive,is the engine light on or not,meanig the management light?for start if the actuator was faulty the check engine light would have been on.....
Old Aug 3, 2007 | 08:06 PM
mbgt's Avatar
afterI drive the car for along period with this problem a get the check engine light and i get a code that means secondary air injection system malfunction
Old Aug 4, 2007 | 07:57 PM
NAZ's Avatar
NAZ
yes there is a secondary air valve on the inlet monifold if that is cloged you ll get malfuncation,the only way to tell is to remove the valve and check if its clean if its dirty its best to replaceits not expensive its about £40.00...........
Old Aug 5, 2007 | 07:32 PM
mbgt's Avatar
is that valve a valve that has 2 hoses and one single vacum hose.
will this secondary valve affect my power
Old Aug 6, 2007 | 04:35 PM
NAZ's Avatar
NAZ
yes if the fault code comes up as secondary air injection malfunction,its gonna effect the power.................
Old Aug 6, 2007 | 06:14 PM
  #9
mbgt's Avatar
i did check that valve and aprently as you suck air the vacum aprently works but i dont know if ot works in a different way, by the way thank you very much for your help
kupiec79
Dec 20, 2008 01:49 PM
hugoestr
Oct 8, 2006 07:27 PM
jampot1979
Mercedes A Class
Jul 30, 2006 01:04 AM
wildmike
Jan 25, 2006 04:35 PM
sidwin
Jan 5, 2004 09:56 AM
