C 230 VIBRATES AT IDLE, ONLY ONCE A DAY???
Mikecruz, my wife’s car about 4 weeks ago started having a rough idle like you had. I changed the plugs no change, no engine codes. I see where Halfthy said to change the crank shaft sensor, in your post you said you changed the cam shaft sensor. I would like to know what one you changed crank shaft or cam shaft.
Last year this car failed to start and I checked for a code and it was the crank shaft sensor. I replaced it, this fixed the problem.
76benz
Aug 31, 2005 12:06 PM
