C 230 SLK Supercharger Question
Old Apr 20, 2010 | 11:47 AM
pjswope's Avatar
Default C 230 SLK Supercharger Question
The Supercharger on the c230 SLK has an electric clutch. Is this clutch used to shift the supercharger from low -> hi speed (ie low boost to hi boost)? OR is this clutch used to "turn off" the supercharger (ie NO boost to normal boost) ?
Old Apr 20, 2010 | 12:04 PM
mrcoyote's Avatar
Talking
That's a good one. I would be very surprised to know that there is a "clutch" on the supercharager that would change the speed somehow to increase or decrease boost. Or that there was a high and low speed. Or to turn it on or off. Without the little blower, the performance would be pretty bad on that four cyl. engine, especially since the compression ratio is low to allow for boost. As far as I know, the supercharger spins all the time by a pulley, which is a fixed diameter. Of course, I could be wrong. I've been wrong so many times it's shocking when I actually hit on something.
Old Apr 21, 2010 | 12:57 AM
pjswope's Avatar
Well actually, if you really think about it, it's not all that hard to do.
The clutch on this supercharger IS an elector-magnetic clutch just like the one on your AC compressor. Using this clutch system along with a simple "planetary gear set" it is easy to allow for the supercharger to spin at one speed (Low boost) when NO power is supplied to the clutch and another speed ("go baby go") when power is supplied. Sadly that is not the case with this unit, which I know now..
THANKS EVERYONE FOR ALL YOUR HELPFUL INFORMATION
Old Apr 21, 2010 | 12:59 AM
pjswope's Avatar
Originally Posted by ForcedInduction
Its an on/off clutch, same as an A/C compressor.
Old Apr 21, 2010 | 11:19 AM
mrcoyote's Avatar
Talking
The blower on my '05 C230K has no clutch. It's an Eaton blower and has a fixed pulley that you can see in the very front of the engine. Perhaps they changed at one point. Is that photo with the clutch a pic of a C230K and if so, what year may I ask?
Old Apr 21, 2010 | 02:28 PM
pjswope's Avatar
98 - 03 C230 SLK For sure, possibly other years.
Old Apr 21, 2010 | 04:51 PM
mrcoyote's Avatar
Talking
OK, thanks. Maybe they changed it later on.
Old May 30, 2010 | 12:26 AM
David A's Avatar
I have read that there is a clutch and it's purpose is to disconnect the supercharger at idle to assist with fuel economy. I also understand its a Roots type twin rotor supercharger.
Solobinoy2k
Oct 31, 2008 02:54 PM
scodari
Apr 29, 2008 05:20 AM
c230benz
Jul 23, 2006 11:08 AM
bazzle
Jul 3, 2005 07:44 AM
erictfree
Feb 13, 2004 09:00 PM
