broke a few vacum lines HELP
well while trying to remove my MAF to get to my KPS crank pos sensor i broke a vacum line connector that goes to intake plenun now how do i rmove the snap ring to get the residue out?
if you talking about the hard plastic tube lines
there should be 2 buttons on the side that you push in...then use a pick to pull out the rest.
or there will be a smaller little tab that fits around the vacuum line at the intake where it broke off. and you push that down or inwards then pull out the excess hose.
Benz_190
Feb 25, 2006 01:44 AM
