Brake Light
Old Apr 3, 2010 | 09:50 PM
mikestrek's Avatar
Smile Brake Light
Hey guys,
I have a 2006 C-230
The dash light on my Mercedes keeps reading "Break Lamp Left"
and Yes, the rear left Break light is out.
Does that mean the bulb is burnt out? or could it be something else?
Also, if it is a burnt out bulb, do you know if it a simple change or does it have to go to a dealer?
Thanks for your input.
Old Apr 4, 2010 | 02:54 PM
Oren76's Avatar
Yes, it means the bulb is burnt out (more then likely). And it is a real simple fix. Go to your local auto parts store and get the correct light bulb. Open the trunk and pull back the carpet cover over the taillight area. It's just tucked into place.
There will be a butterfly screw. Turn in and the back of the tail light with all the bulbs should pop out. Slowly pull it off (so as to not break other bulbs). Twist out the burnt out bulb, replace it and reverse everything to put it all back. Simple.
Old May 26, 2010 | 03:45 PM
mikestrek's Avatar
Default It worked
Thank You. This worked.
alleycat822
May 5, 2011 02:08 PM
bluenose
Feb 14, 2010 07:46 PM
springhillmb
Sep 21, 2007 01:41 AM
