Blower motor stays on
Hi All. I did a search, but couldn't find any fix.
I have a 1999 C280, it's been a good little car.
Today when I turned off the key, I noticed the blower motor was not shutting off. Even with the key removed from the ignition, the blower motor stayed on. I had to pull the fuse (#29) to get it to shut off.
Could someone tell me what the likely cause is? I'm guessing either the blower motor regulator or the climate control. If so, is there a relatively easy way to figure out which it is?
Also, there is a bit of an engine oil leak from somewhere in the front of the motor. Is there a typical area up there that tends to leak? I haven't cleaned the engine yet to find the leak.
thanks
thanks
Excellent suggestion, thanks. Since it hasn't rained in a week here now, the car has had a chance to dry out, and the problem has disappeared. I guess the regulator got a bit damp and malfunctioned, then reverted back to normal once it dried out.
Where would one find the cowl drains on the 1999 C280?
thanks
Dana
thanks
Dana
xb70valkarye
May 8, 2026 08:01 AM
YuCrew
Apr 14, 2004 02:20 AM
