AC problem
Old Jun 25, 2006 | 10:59 PM
ceberus's Avatar
Default AC problem
I have a 2000 280C. I had low freon pressure of 25psi and added a canister to bring it up to 40psi. The AC worked great for a month or so, but then stopped blowing cold. The pressure reading is now 100psi which indicates a possible mechanical problem. Can anyone advise me as to what might be happening and whether I need to take this in for professional repair?
Old Jun 26, 2006 | 02:02 AM
vytamenc's Avatar
Default RE: AC problem
what are both your high and low pressure reading. and honestly if you dont have an a/c licence you could get a large fine for installing r134a to a system. if both your pressures are the same 100 your compressor is not working and the pressures equalized meaning bad compressor.
4XXXX
Sep 1, 2008 01:52 AM
e320drivemecrazy
Mar 11, 2008 06:02 PM
bluebirdnips
Nov 19, 2007 02:34 PM
rameets
Jun 20, 2007 02:43 AM
legenesepimp
Nov 4, 2005 01:36 PM
