99' C280 V6
Someone could help me. please!!
My 99 C280 V6 132K miles drove for 10 miles. Itcouldn't startafter parking for 10 minutes (the engines cranked but didn't turn over). I pulled the plug wires out and test as a result, no spark to the spark plug.
After hour, I come back to start the engine and it is on.
Ithappenedmore than 4 time a week.
I don't know what is exactly problem with this.
I think it should be igniter component or crank sensor.
What do you guy think ?
][&o]
][&o]
Most likely the crank sensor. Are you getting a tach signal when engine doesn't start? If not the most likely cause is the crank sensor. One other thing to keep in mind.Carry yourspare key w/ you & try it when engine doesn't start. This could also be a DAS issue.
