2005 w203 Comand
Help!!! I own a 2005 C230 which I purchased without the comand. I didn't think I would have a problem installing it after the fact. I purchased a unit from MBdoctor.com and it was a very easy install. My problem is that the 2005 C203 model doesn't come with a GPS Antenna if you don't have the Comand option. Prior to 2005 it was pre wired in all the c-classes.
I used an after market antenna mounted under my dash in the Factory recommended location (for retrofits) but it doesn't work well at all. The comand is lost 60+% of the time. (I also moved the antenna to several diferent locations. all bad)
I had a splitter made and ran a cable to the factory antenna before I knew it was just a cell phone antenna and well... needless to say that made it worse.
I was told by Sammy of MB Doctor that to install the factory GPS Antenna I would need to change out my rear window and the cost would be ridiculous. I already spent much more than if I had purchased the option at the time I bought the car. (But it is a very rare option in Hawaii so I could not get it at that time)
Dose anybody know of any options I should consider. I am willing to change out my rear window if that's all I can do, but a cheaper, effective solution would be preferred. Is there a glass mount antenna from another manufacturer I could use?
If I must use the factory antenna, could anybody tell me the parts list? I can't seem to get much help form the local Mercedes dealer here. They are the only ones in Hawaii and with no competition, they can get away with ignoring customers.
I truly apreciate any help you can give.
If it was me then i would call the Mercedes helpline, in the UK (here) there's a 0800 (1800 in the US) number for help and assistance.
Post back if you dont have this there and I could give you the UK number, Good Luck.
Thanks for the info. I called the # and they still could not help me. I think I have the problem solved now with the help of a great parts guys at Mercedes of Honolulu but I'm anticipating one more glitch. I'll post how it goes once I attempt the fix.
Carcrazy
Nov 17, 2006 10:35 PM
Supernad
Mar 22, 2006 02:32 PM
