2004 C240 Smart Key not recognized
Old 11-21-2010 | 12:43 PM
rgh's Avatar
rgh
Default 2004 C240 Smart Key not recognized
Hello all,
I am new to this forum & am looking for a little advice. I have a 2004 C240 which has been parked in my garage for several months. Yesterday when I went to start it, it would not recognize the key. Nothing happens when I put it in the EIS. I have read that battery voltage may be the problem. I show 12.4 volts on my volt/ohm meter across the terminals. Has anyone else experienced this kind of problem?
Thanks.
Old 11-21-2010 | 01:00 PM
chassis221's Avatar
sounds like everything is ok with the battery but you could need a jumper pack. if its been sitting for a few months itll need to be jumped...its a benz.also try leaving the key in the ignition for a several seconds first before trying to crank it.
Old 11-21-2010 | 01:24 PM
rgh's Avatar
rgh
Thanks for the quick reply, chassis221. I did try jumping it. It is not seeing the key, so I can't even turn it to position 1, much less to crank it...
DAN_PR
09-05-2009 12:57 AM
Ilkeclk320
04-28-2008 03:48 PM
cisco_torrez
12-05-2007 12:04 AM
utahking
05-07-2006 09:24 PM
cisco_torrez
04-04-2006 08:57 PM
