2004-C230k Oil Filter-where is it??
Old 03-26-2006 | 09:43 PM
geno1's Avatar
Default 2004-C230k Oil Filter-where is it??
I'm doing my 1st oil change since warranty expiration. I've done many oil changes on all kinds of cars but I can't find the the oil filter for the life of me! Help!!!
Old 03-26-2006 | 10:28 PM
sleepwalker's Avatar
Default RE: 2004-C230k Oil Filter-where is it??
beside power steering oil reservoir.
Old 03-27-2006 | 12:54 AM
geno1's Avatar
Thanks for the reply but I still don't see it. I see the power steering pump bracket to the right attaching it to the block. The coolant hose is behind the PS pump and the alternator is below. Don't see anything under the exhaust manifold or below the alternator either. I think I'm looking for a canister for the filter, but I don't see that or a screw-on filter.
Thanks in advance!
Old 03-27-2006 | 01:38 AM
fly_major_fly's Avatar
You did not see it because you approached the car like a Detroit make.
It is not under or on the side.
It is on the top.
It looks like an up-side-down can with a plastic bottom.
Use your eyes, just scan the top surface of the engine. Think less and you shall see.
Filter is not a problem here. The problem is newer Benz engines are designed in a way that draining the oil is not encouraged. Oil is supposed to be sucked out via dip stick hole.
On my 202, I have to remove the plastic cover under the oil pan if I want to drain. The screws and the nut-kind-of-catch plates holding the plastic cover are not designed for frequent removals. Is it the same way on 203, Sleep?
Old 03-27-2006 | 02:31 AM
yes in 111 engine.
they are always visible at front (less the covering of course).
Old 03-27-2006 | 12:20 PM
Snorkohls's Avatar
Geno,
I just completed an oil change on my 02 C-240 yesterday. The previous post is right, the oil filter is on top, and as you face the car, it should be on the right. It is a cap, because it takes a paper filter. Mine is directly in front of the oil fill cap. It should have a torque setting written on it, with an arrow showing which way to tighten it. It is true that they usually suck the oil out the top, but if you only take off the back protective plate, there is less bolts to remove on the underside. Make sure you have a big enough container, it holds a lot more than my Dodge. Alos be sure to change the O-rings. Hope this helps.
snorkohls
Old 03-27-2006 | 07:40 PM
geno1's Avatar
Called the dealer and the canister is supposed to be at the top rear of the engine on the driver's side. It does have a hex nut molded onto the canister top, and when unscrewed comes off with the filter intact. I'll let you know how it turns out. Man....I hated to even call the dealer about this!!!
brudd
11-23-2007 07:37 PM
C230K
11-04-2007 08:05 PM
spicybabes
10-04-2007 10:09 PM
andygroove
04-24-2007 03:06 AM
andyd987
11-01-2006 07:55 PM
