2003 Mercedes C230 Kompressor
Old Sep 26, 2015 | 03:22 PM
bnzone's Avatar
Default 2003 Mercedes C230 Kompressor
Hello I have a C230 2 door 2003 and I am having the red screen with battery sign come up and now my key remotes won't set alarm and lock and unlock doors. Doors lock and unlock by pressing button on dash and I have put new batteries in key remotes and checked fusses 8, 9, and 41 for alarm and all good. Had battery checked and charging system and was told all good but that my voltage regulator was not good. Could this be my issue for alarm and remotes not working? I know I will need to replace alternator now, any ideas? Thanks in advance.
Old Oct 24, 2015 | 02:11 PM
gilgorm's Avatar
I would check your remote batteries again. Batteries should be 2025 with + side up. If the remotes are functioning the red check light on the remote should light up. If all is OK then either the car battery or the remote sensor(s) could be faulty.
Based on your description and remotes are double checked then car electrical system must be at fault. Car battery must have enough power to actuate locks and alarm.
Good luck
toopeh
May 19, 2013 05:27 AM
pfunkadelik
Jan 23, 2011 10:21 AM
paypaboi
Apr 2, 2007 08:46 PM
raiderette02
May 25, 2006 06:24 PM
raventex
Aug 27, 2005 12:43 PM
