2003 C230 misfires
Old Jan 19, 2009 | 05:02 PM
tfilan's Avatar
Default 2003 C230 misfires
Help!
My C230 has 85000 miles. I am the original owner. About a month ago, i was in stop and go traffic for three hours. The next day, after the car warmed up , it felt like it was misfiring. I drove it for about an hour, and the check engine light came on. I figured I was due for a tune up and did it myself with the help of the forum. The car still misfired and the car had error code for misfires on 1,2 & 3 along with upstream O2 sensor. I relplaced the fuel filter. I then replaced the sensor and it still runs poorly. I did a compression test and #1 was 140, and 2, 3 & 4 were at 160. I did a wet test on #1 and it was still 140. Since I have been running regular gas in the car, I thought that there was carbon build up in the cylinders. I used a marine product called "power tune" to clean out the cylinders. I sprayed the stuff into the air intake with the car running. I then sprayed this stuff directly into each cylinder. The car still misses and the codes alway start with misfire in cylinder #1. It then goes to 3, then 2 and eventully 4. I tried switching coils 1 and 4 with no change. The spark plugs (original) looked like they were wearing normally.
Any sugestions are welcome. (I already agreed to use only high test gas).
Tom
marshall
Jan 15, 2010 07:48 AM
StevenC
Dec 20, 2007 11:32 AM
ps2cho
Sep 11, 2007 07:51 PM
ejoeyz
Jun 9, 2006 01:15 PM
goodluck
Nov 2, 2004 04:51 PM
