2002 C240 Crankshaft Position Sensor location
Old 03-26-2007 | 08:15 PM
orlitex's Avatar
Default 2002 C240 Crankshaft Position Sensor location
I have a 2002 C240 and am currently trying to find the position of the crankshaft postion sensor....does anyone happen to know where it is? Also does anyone know how to clear the SRS airbag warning message. I had to replace the lock (drivers door) and when the door was being repaired the airbag had to be unpluged so the SRS warning is now going off but i have no clue as to how to reset it?
Old 03-27-2007 | 02:21 PM
xvvvz's Avatar
Default RE: 2002 C240 Crankshaft Position Sensor location
SRS light resets are usually more complicated. I have read some places that you must have the STAR scanner to reset them. Other places have stated that a few other high-end 3rd party scanners can reset SRS codes. Apparently a basic OBD II scanner isn't going to do it.
Old 03-27-2007 | 02:39 PM
xvvvz's Avatar
Here is the crank position sensor:
http://www.detali.ru/cat/oem_mb2.asp...075&SGN=04
Old 03-27-2007 | 02:50 PM
orlitex's Avatar
much appreciated I have to let yall know how it goes ???
Old 04-02-2007 | 03:27 AM
orlitex's Avatar
easy fix if you have the right tools and patience , sensor was 109.00 and is located on top drivers side of the transmission bellhouse, all the air intake had to be removed and the valve cover ventalation tubes.
Old 06-04-2008 | 02:20 PM
Sonarcade's Avatar
wonderful diagram. Does anyone know if there's a version of this for a 2000 C230? I'm looking for the camshaft position sensor and tried to use the one link here to no avail. But perhaps I'm blind. I can take a picture of the engine if that would help any. If there's no response to this, I'll assume that my question was off topic and needs to be in a thread of its own.
Old 10-13-2015 | 09:37 PM
sebring65's Avatar
Default 2001 crank shaft censor location
Looking for this year also.do they change where they put them every year or something? lol
Old 12-30-2015 | 01:07 PM
Aaronl522's Avatar
Default Hello, can someone tell me how to make a new post
I need to find the "camshaft position sensor" on my wife's 2005 C230k sedan. I've combed the net with no luck. I frequent this website as I have Two c230k sedans and work on them regularly. Cars misfiring on all cylinders. I have checked all other causes. Replaced p2 sensors etc. Just need to know where the cam position sensor is. Please help thanks in advance
lucky chucky 1
07-09-2015 03:17 AM
naseeb
10-24-2011 09:22 AM
kupiec79
10-28-2009 10:26 PM
BenzoDJ
03-30-2007 09:01 PM
sdanville
09-20-2004 05:30 AM
