2001 C240 Multiple error codes, won't drive
I have a '01 c240 with 115K miles. Display shows 7 error codes: battery alternator, brake assist, restraint system, light sensor, ABS system, ESP, battery undercharged. I cannot move the transmission out of park and the fan does operate, causing the car to overheat after 15 minutes of idle. If I start the car enough times, all but the battery errors clear and I can put the car into gear.
Any idea of the cause and solution?
