1999 C280 (Engine Issue) & ABS/ESP Light
Old Jun 3, 2005 | 05:19 PM
phidelt0135's Avatar
Default 1999 C280 (Engine Issue) & ABS/ESP Light
Strange problem, yesterday I was ready to park and go into idle when the engine started shaking violently - so much so that the entire car was shaking. I opened the hood to take a look and it looked as if the engine was trying to rock itself right out of the car. After I parked and went to dinner - came back and the problem was non existent - any ideas?
Also - The ABS/ESP light come son from time to time and when it does, I can't use the cruise control. Is this a sensor I can replace?
Old Jun 3, 2005 | 06:23 PM
sleepwalker's Avatar
Default RE: 1999 C280 (Engine Issue) & ABS/ESP Light
it happens to the engine whenever there was a misfire. the control unit will shut-off the misfiring cylinder to prevent flooding of the cylinder and won't be re-activated until you re-start the car. in your case, it shuts-off at least 2 cylinders which cause the shake.
engine will be fine after restart.
do maintenance...fuel filter, sparkplugs, etc.
check your brake light switch.
it's not sensor because it is intermittent.
Old Jan 4, 2006 | 02:09 PM
You were right. I found instructions on how to replace the brake light switch. It took me all of 20 minutes and a screwdriver and I was able to replace it. The BAS/ESP light and the ABS lights are gone.
Thanks for your help
Old Jan 5, 2006 | 01:37 AM
you're welcome.
that seems half a year ago
onehooptyman
Feb 26, 2011 02:21 PM
abcnerdd
Mar 20, 2010 02:38 PM
5 Salt
Nov 20, 2006 03:52 PM
GERMAN MAD
Oct 8, 2006 09:02 AM
rmt6668
Apr 28, 2006 05:53 AM
