06 c230 Fog Lights
06 c230 Fog Lights
How do you turn on the Fog lights for the C230 06 Model? My regular lights turn on autmatically at night but the Fog lights do not turn on at all. Only when I shut the car off the fog lights turn on for a sec then turns off.
Thanks,
Reggie
Thanks,
Reggie
RE: 06 c230 Fog Lights
the rear fog light is on the left tailamp, it is only on one side. if you pull your light switch all the way out you will see that there is a brite light that will light up on the left rear tail light. it is incorporated into the taillamp assembly. it is designed so that the back of your car can be seen when it is foggy. I believe it is the inside rear park light that will light up brite when you turn on the rear fog.
