06 c230 Fog Lights
How do you turn on the Fog lights for the C230 06 Model? My regular lights turn on autmatically at night but the Fog lights do not turn on at all. Only when I shut the car off the fog lights turn on for a sec then turns off.
Thanks, Reggie |
RE: 06 c230 Fog Lights
when light switch is in park lights or headlights pull out the headlight switch for front fog and pull out again for rear fog lights.
Post a pic of the rear fog lights
I do not think the 06 has a option to pull the switch out. I tried to pull it but it only turns right and left if your speaking of the light switch that turns the headlights on and off.
it does pull out, but you have to turn onthe lights to be able to pull out the switch.
the rear fog light is on the left tailamp, it is only on one side. if you pull your light switch all the way out you will see that there is a brite light that will light up on the left rear tail light. it is incorporated into the taillamp assembly. it is designed so that the back of your car can be seen when it is foggy. I believe it is the inside rear park light that will light up brite when you turn on the rear fog.
Turn your light swith all the way to the right, go up one click , pull out once for fogs, pull out farther for back, 2 lights wil be one on the right side of button :)
