Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
Keyless Go Problem
Old Apr 21, 2018 | 07:44 AM
dsegel's Avatar
Default Keyless Go Problem
We recently purchased a 2015 MB with the Keyless Go feature. The car is Certified Pre-Owned with only 12,000 miles on it. We took it on a short trip and on day 2, all of a sudden, we were not able to start the car with the start button or lock of unlock the doors by using our hands (with key nearby). We were able to start the car by inserting the key in the ignition and we were able to lock and unlock the car using the remote key fob.
We called our dealer and were told to bring it in when we get back. They could not offer a solution over the phone.
So the problem continued for a couple days, then all of a sudden started working again.
Could anyone shed any light as to how this happened and whether there should be concern.
Old Apr 24, 2018 | 01:08 PM
PelicanParts.com's Avatar
I would imagine that this setup is similar to BMWs and it sounds like the fob may needed to be charged - this is done by inserting it in the ignition. I would inquire with your dealer about this. Other members will likely chime in with their expertise as well.
Old Apr 24, 2018 | 02:35 PM
dsegel's Avatar
Hmmm, very interesting. I did inquire from the dealer but haven't heard back. The fob is battery operated, would it still need to be charged?
Old Apr 24, 2018 | 05:59 PM
I'm not sure if it's the same for MB, but for BMWs; yes, you're still able to charge it by putting the fob in the ignition even if it has a battery inside.
bossgobbler
Sep 15, 2008 08:55 AM
tmccracken
Mar 11, 2008 04:41 PM
brianlin16
Nov 5, 2007 07:57 PM
Speedfreek
Aug 28, 2007 05:12 PM
nycshyne69
Apr 9, 2006 12:26 PM
