Interior What have you done to the inside of your ride? Talk about it here.
moonroof
Old Aug 1, 2005 | 08:27 PM
240Dalex's Avatar
Default moonroof
can u open a moonroof manually on a 83 240?
Old Aug 1, 2005 | 09:40 PM
C280 wizard's Avatar
Default RE: moonroof
Yes, all electric sunroof's have a manual function. In your toolkit there is a crank. My crank goes into a slot under the front interior light and allows you to crank it open or shut.
Old Aug 1, 2005 | 09:43 PM
240Dalex's Avatar
i dont have a toolkit
do u have a pic of the crank?
slot-were u say thers supposed to be a slot theres a hole in mine?
Old Aug 1, 2005 | 10:00 PM
Mine looks like a bar bent 45 degrees with a philips type driver at one end and the other is for turning. I hve a 99 C280, so the design might have changed. Got to a dealer and they can do it in a snap for you and buy yourself a crank and find out why it didn't close, or open
Old Sep 26, 2005 | 11:12 PM
NICKSPA's Avatar
The '83 240D (123 Body) electric sunroof motor is in the trunk on the driver's (left) side. The sunroof can be moved manually by turning the motor manually. If I remember correctly, it is either a 17 or 19 mm drive on the side of the motor which can be accessed through a small trap door in the trunk / quarter panel liner.
rvelez
Jul 6, 2007 11:41 AM
ecology12
Oct 4, 2006 09:48 PM
steelergrl
Sep 26, 2006 05:32 PM
sdanville
Aug 5, 2006 09:56 PM
arkansascarnut
Mar 16, 2006 02:00 PM
