Interior What have you done to the inside of your ride? Talk about it here.
Cassette Holder in '90 190E
Old Jul 29, 2005 | 05:57 PM
Lug1115's Avatar
Default Cassette Holder in '90 190E
I just got a 1990 190E. As you may know, right above the radio is an area where you can hold 8 cassettes. In this modern age, this does not serve much of a purpose (mainly because I put it a unit with a cd player). Does anyone have any suggestions as to what i can do with this area in the center? Is it easy to pull out? Any ideas or comments would be greatly appreciated. If you've done something similar, pics would also be of great help. Thanks a lot.
Old Jul 29, 2005 | 06:32 PM
Lug1115's Avatar
Default RE: Cassette Holder in '90 190E
I was wondering if maybe it would be possible to install a navigation system in that spot. From what I understand, as long as I can connect a power supply and a gps antenna, the system should work. It doesn't even have to be a COMAND system. Am I just full of it or is this a possibility?
Old Jul 29, 2005 | 07:44 PM
dbenz's Avatar
You have a few options. If you dont already have it to fill the space.
Aftermarket head unit and Equalizer
Command Unit
DVD Player and TV screen
Cubby Hole for storage (Try Ebay for those)
CD Holder like this....
You'll probably need to do some custom work tho.
Old Jul 8, 2006 | 01:34 AM
marknute's Avatar
i believe there is a storage tray availible as an option from the dealer, it was for the european market but with the right connections im sure you can get one.
Old Jul 13, 2006 | 01:45 AM
duxdevil's Avatar
I installed a custom navi system in my car. check out the forum in audivisual and you can see the whole project
mellobenz
May 23, 2014 12:25 AM
platonmind
Mar 12, 2011 06:10 PM
tomard
Feb 11, 2009 08:54 AM
sbeemish
Oct 29, 2004 01:16 PM
cgauldin
Aug 19, 2004 11:53 AM
