Wipers Don't Work
Old Jul 13, 2010 | 08:25 AM
arkydoodle's Avatar
Default Wipers Don't Work
Recently my wipers quit working on my 1985 300D. I checked the fuses with a volt meter, all showed continuity from post to post. I figgered it was probably the combo switch (turn signals, lights, etc all work fine, just no wipers or washers) so I removed the lower kick panel (under the steering wheel) and plugged in another combo switch ( I did not remove the switch on the steering column). Same results, everything seems to work except the wipers/washers........so does this mean it's a bad wiper motor or is there another electrical "opportunity" (relay, fuse, switch, etc).......THANX!!
Old Jul 13, 2010 | 09:37 PM
attila's Avatar
use a test light to check fuses. volt meter has no draw and will not show bad connections. do you have power at the motor?
Abba1941
Jul 17, 2014 06:31 AM
MercedesLaw
Dec 11, 2010 07:45 PM
arkydoodle
Aug 6, 2010 03:35 PM
horseybird
Oct 27, 2007 02:12 PM
Sphil98clk320
Nov 26, 2004 08:43 PM
