Wipers Don't Work on 1985 300D
Recently my wipers quit working on my 1985 300D. I checked the fuses with a volt meter, all showed continuity from post to post. I figgered it was probably the combo switch (turn signals, lights, etc all work fine, just no wipers or washers) so I removed the lower kick panel (under the steering wheel) and plugged in another combo switch ( I did not remove the switch on the steering column). Same results, everything seems to work except the wipers/washers........so does this mean it's a bad wiper motor or is there another electrical "opportunity" (relay, fuse, switch, etc).......THANX!!
THANX for the info.......I'll re-check the fuses and the possible corrosion issue.......What /where is the controller relay (part number?)....Can this item be purchased at a local auto parts store/MB dealer/ebay??
