While I was driving home...
Old Jul 15, 2007 | 02:20 AM
samlynn79's Avatar
Default While I was driving home...
... from the movie theater, I approached a red stop light, and slowed down. I got to about 20 miles an hour when it turned green, so I accelerated. As soon as I did, the "Check Engine" light came on, and the engine started running like a cylinder wasn't firing. I pulled over, shut off the engine, and waited a few seconds. When I started it back up, it purred as usual, no obvious problems, and performed excellently all the way home. The "Check Engine" light is still on, however. Tomorrow I'm going to pull all the plugs and probably replace them. Is there any way to turn off the "Check Engine" light without taking it to a mechanic and paying them to do it?
Specs on the car - 1997 C280 (arctic white), in immaculate condition, 78k miles on the clock. Bought it last October from it's only owner for $7,800.
Old Jul 16, 2007 | 02:50 AM
snanceki's Avatar
Default RE: While I was driving home...
Likely ECU picked up a (serious) misfire and put engine into "limp home".
System reset (cancelled limp home) with ignition off.
Light (CEL) should go off after a few trips IF the problem ihas self corrected or what an usual set of circumstances but if it came on usually points to something needs attention.
Nwer OBD systems have a memory that is accessible that tells you why the CEL came on. Not available with your model.
Stuart.
stevembenz500
Oct 3, 2009 07:06 PM
kiblu
Aug 8, 2006 01:30 AM
Barry1173
Apr 2, 2005 01:33 PM
kfarah
Dec 30, 2004 09:04 PM
marklevine
Feb 18, 2004 03:48 PM
