whats up with this
Old Sep 24, 2008 | 09:19 AM
glenn1's Avatar
Default whats up with this
got an s500 than cold runs when warms up shuts off starts back up then cold
Old Sep 24, 2008 | 08:39 PM
MBZTech's Avatar
Default RE: whats up with this
You got a bad Crankshaft Position Sensor. They go bad when they get hot and stop sending a signal. With no position of the crankshaft, the car turns off. When it cools back down, it starts working again.
Old Sep 25, 2008 | 01:17 AM
snanceki's Avatar
Likely th Crank Position Sensor CPS. DIY type job subject to competence.
However, get the codes read. CPS doesn't set any codes.
Stuart
Old Sep 25, 2008 | 07:12 PM
MBZTech's Avatar
CPS do set codes sometimes. Any usually after you replace the CPS, you'll want to reset ring gear adaptations.
Old Sep 25, 2008 | 09:19 PM
glenn1's Avatar
ty for that the info because thats what it does warms up nice shut off won,t start at all until cools off
Old Sep 25, 2008 | 09:22 PM
glenn1's Avatar
hey stuart ty for the info cps would do that
Old Sep 26, 2008 | 08:40 PM
glenn1's Avatar
Default can,t find cps
looking for the cps can,t seem to located looking for this item for 15 min today where is it located in an 2000 s500 .....
Old Sep 27, 2008 | 12:51 AM
snanceki's Avatar
Default RE: can,t find cps
Upper LH bell housing ie back of engine near fire wall.
Stuart
Old Sep 27, 2008 | 01:13 PM
  #9
glenn1's Avatar
ty stuart
agn105
Mar 3, 2006 03:07 PM
affalterbach65
Jan 24, 2006 05:33 PM
WANTED_560SEC
Nov 12, 2005 07:13 PM
Gusto
Jul 19, 2005 04:07 AM
SuperCarMan808
Feb 1, 2005 10:14 AM
