W203 Passenger Central Locking
Old Mar 24, 2008 | 08:22 PM
dc1701's Avatar
Default W203 Passenger Central Locking
Looking for some help guys, W203 passengers side central locking button bounces up and down each time the car is locked or unlocked using keyfob. MB says its the "latch" even though they haven't seen it and want an arm leg to repair. I've managed to locate the the screws on the door panel so Ishould be able to remove that.
What would be great if anyone has any tech info on how to do this thisrepair and any phots of the parts making up the central locking in the passenger door.
Cheers
Del
Old Mar 26, 2008 | 03:47 PM
xrebil's Avatar
Default RE: W203 Passenger Central Locking
Hi Del,
Very common problem on most of the Mercedes Range. You will require an entire door lock, im afraid there is no repair method. It can also be quite tricky to do yourself.
You will have to remove the door card; there is a couple of Torx 30 screws, 1 behind the SRS plastic cover, and another behind a plastic trim under the inner door handle. You will need to remove the tweeter also!
Then pull on the door card around the edges, and lift it up over the window seal to remove- remove all plugs etc from the card!
Then you will be able to see whats inside. You may need to remove your window runner to remove the door lock as there isn't a lot of space!
Hope this helps,
Rob
rfarty
Mar 11, 2012 08:44 AM
delboy277
May 12, 2009 05:19 AM
mstanglin
Sep 20, 2004 03:30 AM
HardeepG
Aug 22, 2004 08:17 PM
forfar4
Jul 4, 2004 02:42 PM
