W201 190E 2.6 Fuel Distributor
I noticed my daughter's car after initial starting would sputter for the first 12 seconds. After that, everything would be fine. I already changed Idle Control Valve, Fuel Pressure Regulator, and, also, the Cold Start Valve. I went to a garage shop and I was told it could either be the Fuel Injectors are bad, or, the Fuel Distributor. The mechanic did not hook up any test equipment. Since I have two units of newer looking used Fuel Distributors, I nstalled both of them. However, on each of them, the car won't start anymore,
Can anyone please direct me on the proper installation, what must have I done wrong?
Is this something the home mechanic cannot perform, are there test equipment required to calibrate or fine tune the FD for proper operation?
Please help.
Nes
Please help.
Nes
