gas leak at fuel distributor on 190E 2.3
Old Apr 15, 2006 | 03:29 AM
drolyat's Avatar
Default gas leak at fuel distributor on 190E 2.3
I wondered if anyone knows how to fix this. Gas started leaking where the plastic fuel block attaches to the fuel distributor.I changed the little O rings and that worked for a while then I changed the plastic fuel block and O rings and that worked maybe 2 weeks. A mechanic told me I would have to change the fuel dist. to fix it. I t barely seeps but still leaks. Any ideas?
Thanks in advance!
Dean
Old Apr 25, 2006 | 09:03 PM
Leo L.'s Avatar
Default RE: gas leak at fuel distributor on 190E 2.3
The block is the EHA i think. There should be to tiny gaskets that go in the fuel distributor mine are green if they aer good and it is leaking, with the two screws that hold it in tight, and it is seating flush aginst the fuel distributor then mabae try replacing the eha if it is scared up or bent.
RICH34
Oct 6, 2009 12:32 PM
nescid
Jul 23, 2008 12:49 AM
krhoad
Jul 2, 2008 10:34 AM
cmscott16
Feb 17, 2007 06:53 PM
1990300SELMAN
Apr 14, 2005 10:59 PM
