w163 ml320
Old Mar 29, 2025 | 08:55 PM
QmY727's Avatar
Default w163 ml320
Hi All.
I have a w163 ml320 which dose not start .So i am seeking some urgent help .
My question is relay k8 pins 85 and 86 i am getting the following readings
ignition position 2- 0v
ignition position 3- 3.5v
relay k12 has got 12v on ignition position 2 and 3
If i shorten k8 pins it turns over
ignition barrel ok
immobiliser ok going by the blinks of led
My question is what controls that voltage being sent ?
Is it the aam ?
Dose it have a fuse or a relay?
Does it need to be reprogrammed if i install another one ?
I look forward to the knowledge being shared thank you
mario
ehedin
Jan 19, 2014 10:02 AM
starbo
Jan 31, 2011 06:26 PM
rickyb
Oct 15, 2010 05:02 PM
sdanville
Oct 29, 2008 05:42 PM
komatsu
Oct 23, 2005 05:39 PM
