valve cover baffle
Old Sep 29, 2008 | 08:19 PM
byhw's Avatar
Default valve cover baffle
oil leak from the baffle and can not get the baffle remove off the valve cover( passenger side )on theC240. Any special tool or trick I need to remove the baffle off the valve cover?
Brought the black sealant #003-989-98-20-10 from dealer and they stated that this is the proper sealant for the baffle.
Any help or guidance would be greatly appreciate with regards how to remove the baffle off the valve cover. .
Old Sep 29, 2008 | 08:22 PM
MBTECHINFO's Avatar
Default RE: valve cover baffle
there should be 2 t25 torx screws on it. remove them and then pry the baffle/ oil separator off. the sealant is strong!
Old Sep 30, 2008 | 08:56 AM
byhw's Avatar
Thanks for the info. I removed all the torx screws but still can not "pry" the baffle off the valve cover. Any suggestion or tool? I do not want to bend or damage the baffle since the old sealant is strong.
sal911
Sep 19, 2010 11:05 AM
Steve's
Mar 16, 2010 07:08 PM
Parshman15
Apr 12, 2007 01:30 PM
charIie
Jan 3, 2006 06:33 PM
76450SL
Jan 19, 2005 10:23 AM
