V8 swap
RE: V8 swap
Yeah its been done before.
Heres a 560 series engine in a 190.
For more info...go here. http://www.geocities.com/shvoldum/main.html
A 4.2 V8 (M119) has been fitted into a 190 before. 380SL engine will fit as well as a early SL500 engine. Even American engines have been swapped in like Ford & Chevy small blocks. Lots of work required.
RE: V8 swap
ORIGINAL: mrl
dbenz,
Thanks for the info! I have a small block Chevy looking for a new home...just considering my options.
dbenz,
Also, theres a guy who swapped in a Ford V8 in a 190. He used a corvette/viper rear end.
Lots of work required and your going to have to worry about the weight up front. So you'll have to install springs from maybe a 190E 2.6 or maybe a 400E.
RE: V8 swap
I figured I would have to upgrade the springs. I wonder if the diff and rear axles could take around 300 hp...My engine/trans is a 283(305ho heads, q-jet, cam, 9.5:1) and the trans will be a T5 or T56 (if I can find and affordable one).
RE: V8 swap
ORIGINAL: mrl
Depending on what type of differential and rear axle you have. If you have one from a 2.3 16V, 2.6, Evo I, or Evo II, then you should be fine. The 2.3 8v rear end wont be able to take that much hp.
