Transmission problem 722.699 (722.6) Kick out of gear
Old 10-25-2007 | 07:01 PM
totx's Avatar
Default Transmission problem 722.699 (722.6) Kick out of gear
W210 E 220 T CDI 2000 modell
Simens EGS module
5 speed ATM 722.699 gear box
Stored fault:
F110
50 and F146
51 and 147 Gang not plausible or Gear box rutsch
Code 50 and 51 are cleared when recycling ignition.
Cleared OK
Transmission is not OK, even if codes cleared OK
Allways slipping a little bit when up shift from 3th to 4th.
(When engine are warm)
Car switching to neutral during driving (up from 3th and down to 3th gear(several times)
Locked up in one gear (3th?) (few times)
Going in to emergency program, max 3000 RPM (3 times)
After one of this conditions, tip schift was not working. (might be setting code 110)
When it switch to neutral during driving, I can just shift to neutral and back to drive.
(Maby tip shift not working)
If speed are redused to 30-40 Km, the it would come back to drive.
After re cycling ignition, evry thing is OK.
Just had the car fortwo weeks
Any sugestions are welcome...;-)
Thanos
07-21-2014 03:45 AM
obujdei
07-18-2011 04:24 PM
vanillaice123
10-25-2009 05:57 PM
epowers777
04-12-2008 06:04 PM
gizgrey
03-07-2007 07:00 AM
