Transmission problem 722.699 (722.6) Kick out of gear
W210 E 220 T CDI 2000 modell
Simens EGS module 5 speed ATM 722.699 gear box Stored fault: F110 50 and F146 51 and 147 Gang not plausible or Gear box rutsch Code 50 and 51 are cleared when recycling ignition. Cleared OK Transmission is not OK, even if codes cleared OK Allways slipping a little bit when up shift from 3th to 4th. (When engine are warm) Car switching to neutral during driving (up from 3th and down to 3th gear(several times) Locked up in one gear (3th?) (few times) Going in to emergency program, max 3000 RPM (3 times) After one of this conditions, tip schift was not working. (might be setting code 110) When it switch to neutral during driving, I can just shift to neutral and back to drive. (Maby tip shift not working) If speed are redused to 30-40 Km, the it would come back to drive. After re cycling ignition, evry thing is OK. Just had the car fortwo weeks Any sugestions are welcome...;-) |
