Towing an automatic trans 190
Old Jul 20, 2008 | 08:03 AM
190 Owner's Avatar
Default Towing an automatic trans 190
Should have asked earlier- I am going on a 250 mile trip to pick up the 190.
I have a tow dolly.
Does the driveshaft need to be unhooked for towing this distance?
Will I need anything special to remove it?
Should I rent a trailer instead?
I don't want to make the trip only to find out I don't have what it takes to get it home-
Advice appreciated!
-Rob
Old Jul 23, 2008 | 06:13 AM
190 Owner's Avatar
Default RE: Towing an automatic trans 190
Just back from a 250mile excursion towing the 190-
Posting this info FYI:
The driveshaft is a 1/2 shaft with 6 bolts on the differential end and splines on the other.
The 6 bolts are 15 mil and the nuts are 17. Rubber carrier bearing(?) at the splined end removes with 2 13mil bolts.
Time to crawl under and re-assemble.
tlichy
Apr 3, 2013 09:30 PM
rohitsagar
Apr 14, 2007 02:17 AM
iDark
Feb 4, 2007 08:00 AM
Catch
Oct 14, 2006 01:37 PM
MicheleBe
Oct 24, 2004 11:46 PM
