Topping up the Brake Fluid
I was checking over the fluid levels in my 2002 C240 the other day and noticed that I need to top up the brake fluid (slightly). Question is, do I need to use MB dot 4 brake fluid or can I purchase any dot 4 brake fluid from an auto parts store. Thanks for your help.
RE: Topping up the Brake Fluid
do not top it up not unless the lamp comes on.
if all your brake pads are new and it's still low, then you can add brake fluid on it.
reason: as your brake pad get's worn out, it is normal for the fluid level to go down a bit.
liquid_drop
08-08-2007 04:19 AM
inssane3gt
09-23-2005 02:25 AM
