1973 450sl 429 ford motor sits low
Old Mar 13, 2006 | 12:54 AM
bo's Avatar
bo
Default 1973 450sl 429 ford motor sits low
I have a friend who has a 450sl that someone put a 429 ford motor in. The car sits low front and back. He wants to raise it 2" all around. is there a way i can determine if someone has put lowering springs on the car? or possibly loaded and or unloaded spring height. I just hate to put new springs on and still have the same ride height. Does anyone know where I might find factory ride height specs. He says it already has spacer blocks in all springs. and springs look new. I have heard you can get spring spacers for the rear, will those bring the height up? Or will I be able to see if they are already there or not. any info would be a big help
Old Mar 13, 2006 | 01:58 AM
sleepwalker's Avatar
Default RE: 1973 450sl 429 ford motor sits low
check how many notches on the spring rubber buffer installed.
4 notches is the highest one.
TN009
Oct 2, 2013 12:01 PM
Gaz_57
Apr 18, 2012 04:18 AM
trev0006
Nov 14, 2008 07:25 PM
AMGMercedes
Feb 28, 2006 03:16 AM
AntonP
Sep 17, 2004 01:35 PM
