Top Won't Go Up
Top Won't Go Up
My soft top won't come up on my 94 SL500. Can someone please give me some suggestions. I checked all the fuses and they are fine. I am now in the process of disconnecting the battery to see if this may reset something. Whatever help you can provide would be appreciated!
Gary
Gary
Yes the red light is flaahing not sure if I hear the pump running but I did remove the spare tire and the resevor hoding the hydraulic fluid is full. The cover that covers up the area that the top goes down into moves a little bit ats it. Also I did check the fuses in the trudnk and thsy are all good
eliteproxy
02-26-2012 02:28 PM
Max Macson
04-20-2011 09:18 AM
bernst
11-13-2007 08:56 PM
