Top on 1999 clk 320 cabri won't work
Old Mar 23, 2007 | 07:06 PM
Paulxavier2000's Avatar
Default Top on 1999 clk 320 cabri won't work
I went to start my car this morning and put the top up. I noticed some fluid in the trunk and when I went to close the top it seemed louder than normal. Later i went to put it down and it got really loud and seemed to close backwards or in an abnormal way. i got out and noticed the fluid seemed like oil or hydrolic fluid. it was heavierr on the drivers side and seems to have shifted around as I drove. Now the trunk won't open without the valet key and the top is 99 percent closed except for a little gap.. the little tooth seems to be off and not engaging at the back of the top. I beliive I have a hydraulic fluid leak in the top motor or a hose. is this possible. is there 2 pumps. if so it seems like the one one the drivers side is out. Now I get no sound from the top motor. Does this make sense or am i off. what should i do. Is this expensive?
Thank you in advance for your kind responses!
AnneInCornwall
Aug 17, 2011 03:51 PM
Birddog
Jun 30, 2011 09:58 AM
smith2andrew
Mar 20, 2011 07:07 PM
mcbroomz
Jan 19, 2008 01:49 PM
Brig
Jul 27, 2006 10:10 AM
