Steering column lock vacuum valve "84" 300TD
Old Jun 8, 2018 | 11:37 PM
snbgreen's Avatar
Default Steering column lock vacuum valve "84" 300TD
I followed this links instruction. http://dieselgiant.com/repairignitionlock.htm
After reinstalling the ignition and steering column lock the car will start and run for about 3 seconds then it shuts off. I’m 100% sure that this issue, has to do with the steering column lock vacuum valve. If I physically hold the ignition vacuum valve and press in the piston to release the vacuum pressure the car will continue to run. If I release the piston then the vacuum builds and the engine shuts off
I don’t see what mechinism in the steering column / ignition that presses the piston in when the key is turn to the on position. Do you sell the mechinism that would ingauge the ignition vacuum piston?
Jeff
1984 300TD
Attached Thumbnails Steering column lock vacuum valve "84" 300TD-img_1737.jpg
Old Jun 10, 2018 | 03:31 PM
snbgreen's Avatar
Are these forums active?
Old Jun 11, 2018 | 01:48 PM
PelicanParts.com's Avatar
Hi Jeff - give us a call at 888-280-7799 and one of our Mercedes part specialists will be happy to assist you in regards to your part inquiry.
agreyling
Jan 4, 2011 12:32 AM
Cypressfriar
Sep 29, 2010 01:49 PM
cici235
Sep 16, 2010 09:19 AM
timberfield
Jun 29, 2010 08:32 PM
bubbathang
Apr 8, 2010 12:12 AM
