start problem 500 SL
Thanks. I just pulled the belt,same result. Turned the key starter engaged but couldn't turn over the engine. When this happened I did not notice any warning lights on oil pressure normal,temp. normal,no over rev,no high speed. Just a short trip maybe 1 mile, barely warm.Do you know of unusual engine seizing? Only 115,600 miles. I'll try to turn the crank today before I pull the starter.I must say the starter got some abuse when I had the problem with the fuel pumps and the water temp. sensors. I had to crank the car to the point of needing a jump and then recharge the battery a number of times. The starter kind of sounds like it might have a "flat spot". As always, thanks for your help.I'll let you know of any progress.It's really frustrating cause I like this car.
To update this file. The engine would not turn over,the starter would engage and try to turn but couldn't.(new battery) So I pulled the plugs and tried to crank it over,no luck. Put a wrench on the crankshaft nut and tried to turn over the motor,no luck. I tried to turn in both directions ,no luck.I only had a 14" breaker bar with no extension. As a last attempt I tried the starter again. First and second tries the same,it engaged but wouldn't turn.ONn the third time it turned over freely. Tried again,turned over again. So,put the plugs back in and it fired right up. Sounds good right? WRONG. Now I have a loud knock that came out of no where. Piston,bent valve ? Don't know yet. The engine was frozen what could it be????? That's the big question before I surrender and take it to a mechanic.
At this time I must give credit to "chassis221"for his excellent assistance.He correctly diagnosed my fuel problems, I replaced the temp. control sensor and it fired right up.He suggested (and I hope he's right),that a car of my vintage might have dropped some carbon and that's causing the noise. His suggestion was a quality fuel cleaner,which I've done. Now it's wait and see. Any other thoughts or experiences ?????
1991 500 sl,just replaced fuel pumps,fuel filter and temp. control switch. Ran great for a few days,drove to the store,came out,turned key,all dash lights came on,starter engaged but would not turn over engine. Tried jumper cables,starter engaged but would not turn over. Took battery home put it on charge,dead cell. Installed new battery,same result,starter engaged but would not turn over. Any ideas? Also what is the location of the starter on a 500 sl?
Thanks in advance for your help,it's my first time posting. I'm pretty okay with tools, but I'm looking forward to hearing from SLEEPWALKER and the rest of you experts. THANKX AGAIN,HARLEY GUY
mycarscout
Aug 4, 2010 11:10 AM
sdmfer
Jun 18, 2007 10:09 AM
