SRS light comes on-gauges drop on '06 c280
When driving my '06 c280, the SRS light will come on, the gauges go to zero(speedometer goes to zero) and then they return to normal and light goes off-this happens at least a couple of times daily and is quick when it does. If driving at night, lights go off also and then come back on.???????????
Sounds like you have a faulty instrument cluster. Hopefully you are still in warranty. They can do a short test and likely find CAN faults with the instrument cluster. This will sometimes trigger a check engine light too.
